Axter standard detail drawings
Plywood deck, warm roof, FORCE LINE waterproofing system
WR.P.010 FORCE LINE Skirting Upstand to Brick Parapet
WR.P.020 FORCE LINE Insulated Skirting Upstand to Brick Parapet
WR.P.030 FORCE LINE Brick Upstand Insulated Render System detail
WR.P.040 FORCE LINE Typical Upstand to Axter Rooflight detail
WR.P.050 FORCE LINE Typical Welted Drip to Gutter detail
WR.P.060 FORCE LINE Typical Verge Check Edge detail
WR.P.070 FORCE LINE Typical Parapet Upstand detail
WR.P.080 FORCE LINE Typical Parapet Rainwater Outlet detail
WR.P.081 FORCE LINE Typical Parapet Rainwater Overflow detail
WR.P.090 FORCE LINE Typical Vertical Rainwater Outlet detail
WR.P.100 FORCE LINE Typical Hot & Cold Pipe Penetration detail
WR.P.110 FORCE LINE Typical Change in Roof Level, Box Gutter Edge detail
WR.P.120 FORCE LINE Typical Mansard Edge detail
WR.P.130 FORCE LINE Pitched to Flat Roof Abutment detail
WR.P.140 FORCE LINE Typical Movement Joint, Twin Kerb detail
Concrete deck, warm roof, FORCE LINE waterproofing system
WR.C.010 FORCE LINE Skirting Upstand to Brick Parapet
WR.C.020 FORCE LINE Insulated Skirting Upstand to Brick Parapet
WR.C.030 FORCE LINE Brick Upstand Insulated Render System detail
WR.C.040 FORCE LINE Typical Upstand to Axter Rooflight detail
WR.C.050 FORCE LINE Typical Welted Drip to Gutter detail
WR.C.060 FORCE LINE Typical Verge Check Edge detail
WR.C.070 FORCE LINE Typical Parapet Upstand detail
WR.C.080 FORCE LINE Typical Parapet Rainwater Outlet detail
WR.C.081 FORCE LINE Typical Parapet Rainwater Overflow detail
WR.C.090 FORCE LINE Typical Vertical Rainwater Outlet detail
WR.C.100 FORCE LINE Typical Hot & Cold Pipe Penetration detail
WR.C.110 FORCE LINE Typical Change in Roof Level, Box Gutter Edge detail
WR.C.120 FORCE LINE Typical Mansard Edge detail
WR.C.130 FORCE LINE Pitched to Flat Roof Abutment detail
WR.C.140 FORCE LINE Typical Movement Joint, Twin Kerb detail
Axter provides detail drawings as part of our technical design service. Such drawings should only be used as a guide during the design process and should not be utilised during construction. Axter accepts no liability for misuse of this service.
