Axter home page
Axter home page
ROOFING • GREEN ROOFS
STRUCTURAL WATERPROOFING
SOLAR PV • SINGLE PLY
Loading
ECOFLEX ADH
BBA APPROVED SINGLE PLY FULLY ADHERED, COLD BONDED INSULATED SYSTEM ON TIMBER DERIVATIVE (PLYWOOD / OSB) BOARDED DECK
ECOFLEX ADH is a lightweight, flexible PVC-p synthetic membrane, 1.5 or 1.8 mm thick with an exposed polyester under surface that has been specially designed for widespread use on all roofing projects including domestic, commercial, social and industrial buildings. ECOFLEX ADH contains recycled material and itself can be recycled at the end of its useful life.
PVC-p roof membranes have been in use for more than three decades and are a proven reliable solution for the majority of flat and low slope exposed roofs.
  • Info on Applications
    Applications
  • Info on Performance
    Performance
  • Info on Roof deck
    Roof deck
  • Info on Insulation
    Insulation
  • Info on Surface options
    Surface options
  • Info on Installation
    Installation
Applications
  A tried and tested roofing system using a modern self adhesive vapour control layer with cold adhesives for the thermal insulation and the final PVC-p cap sheet.
  Suitable for use as a single ply fully adhered system on insulated concrete, timber and metal decks.
  Suitable for use on new build or renovation projects.
Performance
  A minimum 25 year design life expectancy (BBA Certificate no. 12/4947).
  High strength and mechanical characteristics.
  Low temperature flexibility.
  Quick no-flame installation.
Roof deck
  Plywood or OSB boards installed in accordance with BS 8217:2005.
  Such boards can be laid to a fall but tapered insulation can be used as an alternative.
Insulation
  Suitable for laying over a range of thermal insulation options including HYTHERM ADH, HYTHERM high density EPS flat and tapered boards.
Surface options
  ECOFLEX ADH is a self-protected membrane in a choice of colours.
Installation and maintenance
  Fully adhered self adhesive vapour control layer.
  Thermal insulation attachment with cold applied adhesive.
  Cold bonded cap sheet with hot air welded laps.
  Installed by trained, card carrying operatives.
  Comprehensive long term guarantees covering product, system design and installation.
  Requires minimal routine maintenance, see Axter's recommended Maintenance Schedule.
01473 724056
Enquiries
Site © 2014 Axter Limited
Other content as credited
