 Applications
 Performance
 Roof deck
 Insulation
 Surface options
 Installation
Applications
A more robust and higher performance alternative to single ply (PVC, TPO, etc.) membranes. |
A tried and tested traditional roofing system using modern mechanically fastened techniques for safe application. |
Also suitable for use as a single layer fully adhered system on insulated concrete, timber and metal decks. |
Suitable for use on new build or renovation projects. |
Performance
A minimum 50 year design life expectancy (BS 8747), available with a 20 year GOLDSHIELD guarantee. |
High melt point and low temperature flexibility ensures stability in all ambient temperatures. |
Stabilised polyester reinforcement ensures stability with no shrinkage, high tensile strength and excellent point loading characteristics. |
Indicative BRE Green Guide 2008 rating: D/C.
See the full details of the BRE Green Guide methodology.
Note - The environmental rankings are based on Life Cycle Assessments using BRE's Environmental Profiles Methodology 2008 and refer to the complete system build up including structural elements, thermal insulation, waterproofing and protection.
Roof deck
Profiled metal decking in either galvanised steel to BS EN 10147:2000 or aluminium to BS EN 484-2:1995. |
The deck should be fixed to the structure in accordance with BS 6399-2 and the manufacturer's instructions. |
Insulation
Suitable for laying over a range of thermal insulation options including HYTHERM PIR, HYTHERM high density EPS and mineral / rock fibre flat and tapered boards. |
Surface options
FORCE 4000 FMG is a self protected membrane available in a choice of six colours. |
Installation
Loose laid or adhered vapour control layer. |
Thermal insulation loose laid or mechanically fastened. |
Membrane mechanically fastened as a single layer. |
Installed by accredited Axtershield Installers. |
Comprehensive long term guarantees covering product, system design and installation. |
Requires minimal routine maintenance, see Axter's recommended Maintenance Schedule. |
