 Applications
 Performance
 Roof deck
 Insulation
 Surface options
 Installation
Applications
A more robust and higher performance alternative to single ply (PVC, TPO, etc.) membranes. |
A tried and tested economical roofing system using modern cold bond adhesives for safe flame free application. |
Suitable for use as a single layer fully adhered system on existing waterproofing systems. |
Suitable for use on new build or renovation projects. |
Performance
A minimum 50 year design life expectancy (BS 8747), available with a 20 year GOLDSHIELD guarantee (depending upon the condition of the existing waterproofing). |
High melt point and low temperature flexibility ensures stability in all ambient temperatures. |
Stabilised polyester reinforcement ensures stability with no shrinkage, high tensile strength and excellent point loading characteristics. |
Roof deck
Existing waterproofing to be used as vapour control layer should be prepared in accordance with BS 8217:2005. |
Insulation
Suitable for laying over a range of thermal insulation options including HYTHERM PIR, HYTHERM high density EPS and mineral / rock fibre flat and tapered boards. |
Surface options
FORCE 4000 FMG is a self protected membrane available in a choice of six colours. |
Installation
Existing waterproofing used as vapour control layer. |
Thermal insulation attachment with cold applied adhesive. |
Cold bonded (RUBIOCOL) application of membrane. Laps can be sealed by cold bond (RUBIOFIX) or torched. |
Installed by accredited Axtershield Installers. |
Comprehensive long term guarantees covering product, system design and installation. |
Requires minimal routine maintenance, see Axter's recommended Maintenance Schedule. |
