| Our services: | ||
| Your assurances: | ||
EXCEL/SPOT |
BBA APPROVED TWO LAYER PARTIALLY SELF ADHERED SYSTEM WITH THERMAL INSULATION ON REINFORCED CONCRETE ROOF DECK |
| EXCEL is a unique robust polyester reinforced Alpa®-mix polymer modified bitumen cap sheet with exceptional performance and ageing characteristics. BBA Agrément Certificate No. 94/3037C applies. | |||||||||||||||||||||||||||||||||||||||||||||||||||
| HYRANGER SPOT is a self adhesive / heat activated polyester reinforced polymer (SBS) modified base layer. The under surface is coated with a self adhesive compound with exceptional adhesive characteristics and the surface is finished with a macro perforated film for safety reasons. | |||||||||||||||||||||||||||||||||||||||||||||||||||
Applications
Performance
Roof deck
Insulation
Surface options
Installation
