Axter’s single ply roofing systems
Range
Axter’s ECOFLEX PVC-p single ply membranes are a proven and reliable solution for the weatherproofing of flat and low slope roofs. They combine a select mix of polymer compounds that encapsulate a polyester reinforcement.
ECOFLEX PVC-p is available in a range of thicknesses with a polyester reinforcement for mechanical fastened systems, (ECOFLEX FM), or with an exposed polyester under surface for full bonding with a solvent free adhesive (ECOFLEX ADH).
Click here for detailed specifications.
Appearance
Both ECOFLEX FM and ECOFLEX ADH are available in a light or dark grey colour and are adaptable to virtually any architectural shape or design.Installation
ECOFLEX single ply synthetic membrane systems are installed by competent roofing contractors who have successfully completed the ECOFLEX system training syllabus. All ECOFLEX trained operatives are issued with an identification card incorporating a photograph that has to be carried at all times as proof of competence.
Attributes and benefits of ECOFLEX PVC-p
Contains recycled material
Design flexibility
Weathering and UV resistant
High strength and mechanical resistance
Low temperature flexibility
Vapour permeability
Superior weld characteristics
Quick installation and detailing
Zero-flame – hot air welds
CE marked
British standard BS EN 13956:2005 compliant
Cost effective solutions. |
Systems
ECOFLEX FM |
Single ply synthetic membrane, 1.5 or 1.8 mm thick for mechanically fastened systems in two colours.
ECOFLEX ADH |
Single ply synthetic membrane, 1.5 or 1.8 mm thick with an exposed polyester under surface for full bonding with a solvent free adhesive in two colours.
Further information
