Axter home page
Axter home page
ROOFING • GREEN ROOFS
STRUCTURAL WATERPROOFING
SOLAR PV • SINGLE PLY
Loading
ECOFLEX FM
BBA APPROVED SINGLE PLY MECHANICALLY FASTENED ROOFING SYSTEM WITH THERMAL INSULATION ON PROFILED METAL DECK
ECOFLEX FM is a lightweight, flexible PVC-p synthetic membrane, 1.5 or 1.8 mm thick that has been specially designed for widespread use on all roofing projects including domestic, commercial, social and industrial buildings. ECOFLEX FM contains recycled material and itself can be recycled at the end of its useful life.
PVC-p roof membranes have been in use for more than three decades and are a proven reliable solution for the majority of flat and low slope exposed roofs.
  • Info on Applications
    Applications
  • Info on Performance
    Performance
  • Info on Roof deck
    Roof deck
  • Info on Insulation
    Insulation
  • Info on Surface options
    Surface options
  • Info on Installation
    Installation
Applications
  A tried and tested roofing system using mechanical fixings for the thermal insulation and the final PVC-p cap sheet.
  Suitable for use as a single ply mechanically fastened system on timber and metal decks.
  Suitable for use on new build or renovation projects.
Performance
  A minimum 25 year design life expectancy (BBA Certificate no. 12/4947).
  High strength and mechanical characteristics.
  Low temperature flexibility.
  Quick no-flame installation.
Roof deck
  Profiled metal decking in either galvanised steel to BS EN 10147:2000 or aluminium to BS EN 484-2:1995.
  The deck should be fixed to the structure in accordance with BS 6399-2 and the manufacturer's instructions.
Insulation
  Suitable for laying over a range of thermal insulation options including HYTHERM FM and HYTHERM high density EPS flat and tapered boards.
Surface options
  ECOFLEX FM is a self-protected membrane in a choice of colours.
Installation and maintenance
  Loose laid or adhered vapour control layer.
  Thermal insulation laid loose or mechanically fastened.
  Membrane cap sheet mechanically fastened as a single layer with hot air welded laps.
  Installed by trained, card carrying operatives.
  Comprehensive long term guarantees covering product, system design and installation.
  Requires minimal routine maintenance, see Axter's recommended Maintenance Schedule.
01473 724056
Enquiries
Site © 2014 Axter Limited
Other content as credited
